TwinTurbo.NET: Nissan 300ZX forum - the compressor housing (cold side) will not bolt up to
Subject the compressor housing (cold side) will not bolt up to
Posted by Dane (Houston) on December 08, 2009 at 2:07 AM
  This message has been viewed 173 times.
In Reply To T2/T25/T28 flanges are all interchangeable. posted by ZLover4Life on December 08, 2009 at 01:35 AM
Message the black compressor inlet pipe. it is clocked wrong even when outlet nozzel is clock to correct. also the stock black pipe is about 46mm diameter, will choke most gt28 and all 30s. you will want a 60 OD diameter inlet pipe for a 2871 and 3071.
The compressor outlet will be a nozzel coupler type connection. stock is a triangle 3 bolt.
Hey if you got the skill and tools im all for it. Its building a WG bracket that doesnt flex and clears when mounted and clocked right which is going to be a pain.
Formerly SpecNATT (Houston)
